j_k_bisson
- Joined
- Oct 6, 2010
- 1,082
Re: 1987 Evinrude 200hp outboard resto/rebuild
1) After you look at the kits and the part for the carbs the answer will reveal it self to you. The gaskets are the same. I also tested the idea with the old parts when I rebuilt them. I put all the rubber gaskets into a butter container of ethenol gas. They did not deteriate.
2) It did show up. But I never used it. I bought it off ebay. They are going for around 20 bucks plus shipping now. I actually found a grinder nut wrench from a cheap Canadian Tire grinder (made in china) that fits the holes perfectly. You might want to check to see if you have a wrench before you buy one. At my local dealer they use a wrench like the one you made. That way they can use a impact one it. My unit was not in very bad shape so I did not need the impact. Just a rubber mallot and a few taps.
3) Yes you should be very concerned where each carb comes from. My project is one hold right now. I plan on rechecking the main jets and locations while on hold. But I'm rebuilding an ATV for a buddy so it is truely on hold. One of my first things to do when I get back to it.
4) I went to the dealer and bought the right hose. It is all ethenol and marine rated. It cost around a hundered bucks when I was done though. But it is done right. With all I seam to get into, you would be suprised to know how many times it was a colapsed hose that was the issue on anything I worked on. Buy the right stuff. It is the right stuff for a reason.
5) I just rebuilt the fuel pump because I was going through everything. All you are replacing is a diaphram, a couple of o-rings, and actuator rod in the rebuild. No test, just preventative mantainence.
Just ask away, I'm always will to help out anyway I can. It's like returning the favor!
Wow...!!! Great Job on the re-build..!! and nice work to all who chimed in with helpful hints..!!
I've got an '87 Evinrude 200XP (STL) that I'm trying to get running right. This thread has helped me get more motivated to dive in, and finish. I started last month, then took some time for important matters... now it's time to finish. It's also prompted me to ask a few questions regarding parts of this project as it relates to my own.
First question... are 'new' carb kits 'better' than older ones..??? I just bought some kits off Ebay that I *think* are 'older' (not sure how old) kits.... are the gaskets in 'old' kits more succeptable to damage from ethanol than 'newer' kits...???
Second, is the black tool that appears 'hinged' for removing the 'caps' off the trim pins..??? If so, where can I get one and how much do they cost..?? I built a four pin 'tool' from a piece of galv steel pipe, and with a big pipe wrench could not turn the pin 'caps'... instead it bent the 'nubs' on the 'pipe/tool' I had made... (!?!?!?!!!) My pins are corroded, and chewed the seal causing an oil 'leak'... I've replaced these pins/gaskets before. Used a buddy's pin 'spanner' tool... but don't remember having a hard time removing the caps.
Third, while I would, by my nature, replace each carb to it's original location after installing the kits, it appears that some of the carbs MAY have different jets installed..?? Need I worry what jets are in the carbs..??
And... what size/type/brand of hose should be used for all the air lines..??
Lastly... I stopped using the VRO 15 yrs ago, but have never rebuilt the 'fuel pump'... any 'test' that might determine if the pump isn't performing..??
Thanks for any help...!!! Jeff, GREAT JOB..!!! Can't wait to 'hear' (about) that puppy firing up..!!!!
