Update 02-26-2011
Update 02-26-2011
Well had a bit of an accident this afternoon after finishing the black paint on the mid section two tone application. Here is what the mid section came out like. Not bad I think.
In the next pic you will see where I put the parts I painted yesterday up an out of the way on the garage door track. Well my own fault or clumsiness I decided to open the door after spraying the black to air out the garage. :facepalm: Needless to say I knock a couple of them down and dinged the new paint. So a bit more sanding and paint and vola here are the two parts with another coat of paint on them.
Since I was taking pics I thought I give you guys a couple of pics of the mid section side panels before I started in on them. They are plastic but the material is not specified on the parts. So I'll check with our paint supplier at work on Monday and find out what to use for primer. Yes I am a plastics engineer working for a tier one supplier to the big three. We do not do painting of plastic in house. We out source it to another company locally. Here are the pics.
Those white marks are gouges in the plastic and paint. So I will need to sand and feather them in. Oh what a fun night I'm going to have tonight!
Also I included in the pic what I use for sanding. I use a right angle die grinder with a 3" scotch brite sanding pads. I use coarse and fine. They don't take too much off which is nice. If I need to take off alot I use 36 grit and 100 grit sand paper pads on the same tool. I find the scotch pads feather better and do not gouge the part like sand paper pads do. A little bit at time and no mistakes. When I rush things fall down and get dinged. LOL
