Woodstock60
Thread starter- Joined
- Dec 14, 2008
- 238
I know that these boats aren't exactly the top of the line, but I picked it up fairly cheap ( boat and trailer) $ 700. And 16' are hard to come by. First pic is the condition i started with. 10,000 rusty self tapping screws held the one piece all aluminum floor down. And the floor felt solid. Underneath the ribbing and floor supports are heavy duty solid aluminum and mostly welded with rivits through the hull, extremely solid. Some of the foam is crap, but i think thats a fairly easy fix. I really need some help and ideas on a few things. My plan is to clean it out and pull up the wet foam, Then puy down some wiring and live well tubing, maybe seal whatever is exposed with some flex seal or whatever someone can recommend, use some kind of expanding foam then reinstall flooring with stainless screws. the flooring was originally installed with some kind of marine flooring cloth glued down , id like to use something thats permanent. This is where i need ideas, what have some of you folks used, any suggestions would be appreciated. Im going to continue this thread tackling one problem at a time, also if anyone has any suggestions on anything else they see on this project, please dont hesitate to chime in. Thank you all
