1987 forcw 125 prop
armenk35
hello. i have a question about the prop size. if i want my boat to go a little bit faster. do i put a smaller prop or a larger prop. and what does the sizes do? 15", 17" and 19 "
thanks
Frank Acampora
Re: 1987 forcw 125 prop
It's not quite that simple! If your boat is correctly propped, it will usually be going as fast as it will go regardless of a prop change.
You can not willy-nilly change props and expect more speed. Indeed , increasing or decreasing pitch from optimum may actually reduce the boat's top speed.
You need to know the speed you are now going. It does not necessarily need to accurate GPS speed because even the inaccurate boat speedometer will most likely show a difference in speed and that is what you are looking for.
You ABSOLUTELY need to know the engine RPM at wide open throttle and maximum speed.
You ABSOLUTELY need to know the pitch and material of the prop you are using now.
And you need to trim the engine to its correct running angle to maximise the potential. You also need to remove any unnecessary weight. The more weight in the boat, the slower it will go.
Just like taking a trip, If you don't know from where you are starting, you can never know how to get to your destination.
john from md
Do a search in the propeller section. There are loads of threads on changing props. I believe that you should have a 13x19 propeller with that engine. That will give you the best top speed that you can get.
Regards,
John
armenk35
guys thanks for your advises. i apriciate your help. i will stay with thatever i have.
