Ridgepatrol
Thread starter- Joined
- Sep 9, 2010
- 23
Re: 1987 Johnson 110hp overheat problem- need diagnostic ideas.
Well, I changed the T-stats.
This has corrected the overheat problem. I had the boat out yesterday and it runs at around 160F while pulling a skier.
They were a real PITA to change. Fifteen minutes to dissemble, and all afternoon to put back together.
The secret I found was to remove the lower rear motor cover, then assemble the parts one at time through that access hole.
Removal of that cover gives much better access to the T-stat housing bolts, and you can use a regular box end wrench on them.
Thanks to all those who helped me out with this problem.
Matt.
Matt.
