1987 Johnson GT 150 power trim problem
Maddog3754
Hi, the power trim switches located on both the bow and stern quit working. The switch on the throttle works fine though. Any ideas on what to check?
jakedaawg
Ohm check the problem switches and wiring to them. The relays and pump are obviously good.
jakedaawg
If both accessory switches quit working at same time I would start at the wiring they share. If one went out before the other then the switches themselves are more likely.
