1987 Mariner Tilt Trim Removal
Wide_N
1987 Mariner 150 HP. I have all of the bolts off and the top pin loose. The whole tilt trim unit is moving around but there does not seem to be enough room for it to get out from between the transom bracket. Any ideas?
Chris1956
Honorary Supreme Mariner
I needed to remove one side of the transom clamp to get the PTT unit out.
Wide_N
Ended up just removing the motor. Thanks
