1987 merc 90 HP full throttle issue
ctrevis7
I ran my boat early this morning on my way to go hunt and it started cutting back a little. On the way back to the ramp I could only get about 5mph at full throttle! Any suggestions?? Maybe a spark plug issue? Thanks in advance!
quicktach
Re: 1987 merc 90 HP full throttle issue
Could be lots of causes. Check for fuel starvation .... gas tank venting OK? Any filters - engine or water filters plugging up ? Has anyone been working on motor ? More detail needed. Happened before ? Could be electrical too ....what is S/N of engine?
CharlieB
Weak spark?
Start with basic troubleshooting
Inspect spark plugs
Compression test
Spark test
DVA test ignition stator
Test fuel pump/flow cranking
Fuel filters
Clean carb
I recommend you perform the top three items on Charlie's list and post back.
