Starcraft5834
Thread starter- Joined
- Jun 2, 2013
- 1,677
bought this boat this year, was tuned up at a marine shop before I bought it, compression good,,,has it out twice, last run three weeks ago,,hard starting, flooded carb,, got her going,,ran perfect rest of day,4500 WOT with 4 blade on my 19.6 cuddy,, every key turn,, boom,, started up first flick..today, would not start, tried,, would not make it,,, I dropped it off at a local marine shop and was asked if I put stable in tank,, nope was my answer... got scolded for that...apparently running unleaded gas causes problems in these carbs,, why?? ethonoyl? does that gum up the carb?
the initial tune up and fluid change performed by a marine shop in the area I purchased this boat,,plugs, dist cap, fluids, filters,, all normal stuff was done,, cleaning and checking carb? probably not... the marine tech I spoke to today said he was going to first test the gas,,said he had something other than stable to straighten out the gas if needed,,, then was going to "boil" the carb in cleaning it,,
why is stable so important? Im learning the hard way on this one,, thanks for input guys..
