FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
I have a 1987 rinker with a 3.0 mercruiser same year and boat runs great for first hour or two then it will start to bog and not run over idle speed any ideas?
Lack of fuel would be first guess, ignition failure would be second guess. Last time carb was rebuilt? Fuel pressure when it starts to bog? Could be lots of things including fuel pickup in tabk...water in fuel...howvis the fuel filters?? Etc....you have some searching to do
So I pulled hose from tank blew that all out I then re ran the vent because there was a huge bow in the line dipping down the going up causing a trap.. I replaced all plugs and wires and distributor cap.. installed brand new carb and changed fuel filter .. put new fuel
The hose from the tank vent needs to make an upward loop to keep any water that might enter the vent from enteringbthe fuel tank. Did you check for water in your fuel? Fuel filter/ water separater clean? If the float is sticking then time for a thorough rebuild....
