1987 MERCURY Black Max SR2
ronnie@69
Was wondering what the rating were for the Merc SR2 Black max 150 back in the day..and the best things to replace on the engine to make it run better all info is welcome.. basically looking for common things to replace looks like most of the components on this 35 yr old out board need to be updated.. although it is running fairly
Dukedog
base 150 and XR2 150 are very much same thing.. XR2 uses different carbs, divider plate and tuner.. these will add a coupla hundred rpm to wot depending on your boat and how its set up... XR2? its more of a "marketing thing"... is it worth tha difference??? its up ta you..
with your boat, doubt you will ever see any difference with any (XR2) parts changes.... jmo
Faztbullet
Slap a new impeller kit in it with bases, throw away the stabilizer/advance module at set timing @23° and go to a stainless vented prop.
ronnie@69
A stainless steel vented prop 3 or 4 blade.. what is the standard timing set at and will the 23degree change help the idol pickup
ronnie@69
Not sure what the impeller is or where it sits very new to The boating world
ronnie@69
ronnie@69
MY CORRECTION 1987 MERCURY XR2 BLACK MAX 150 ..looks like I posted SR2 instead of XR2
jimmbo
With differences mentioned above, the XR2 had a Fatter Power curve in the midrange, resulting in greater Acceleration. Both the regular 150 and the XR2 put out 150hp at their rated rpm, the XR2 just burning a bit more fuel doing so
ronnie@69
Thanks for the info my friend
jimmbo
I'm waiting for someone to chime in that the XR2 was 165 because that is at the upper end of what an engine rated at 150 can actually produce and still be called a 150.
ronnie@69
That's certainly thoughts and theory of some individuals that I have communicated with..Some have made statements that the XR2 150 is actually a 165hp..I wouldn't know I don't have much experience with boats yet..
jimmbo
In 1986, I saw the Power and Torque Curves for the Standard 150 and the 1st XR2. The XR2's power peaked higher(not by much) than the Standard 150, but at a lower Rpm, and the power was dropping by the time the engine was a attaining the Rpm where it was rated at 150
Faztbullet
Service school stated 160+ with the additional mods...all you would see on performance boats was your able to run one pitch size bigger. On Posters hull wouldn't see much difference
Dukedog
"That was one of the differences"
about tha only one that makes any difference..............
Faztbullet
We used to cut 1-1/2" off em (tuners) as we was going up against Junkrudes GT's and ran the 1.87 lower...doggy down low but would walk on out when it got to strung out.
