Re: 1987 OMC Cobra 5.0 idles rough
OK, update on what I got. Checking with the previous owner before doing anything, the shift cable was brand new 2 years ago, they readjusted the shift mechanism and figured it was cheap insurance to replace the cable while adjusting everything. Cable pull on the shift cable is 2.2lbs so the shift cable is good. After readjusting everything the unit shifts into fwd and about 70% of the time is very hard to shift back to neutral, it just sticks and doesn't want to go into neutral. Same with rev, it doesn't want to go back into neutral. The good news is I think i isolated the problem, the ESA shift interupter switch only activated the ESA 4 out of 10 times that manually threw it. I'm assuming that if the ESA isn't dropping the RPM's of the engine shifting is very difficult or impossible. I ordered a new ESA and shift actuator switch. One other note, the shift actuator arm does not move all that much, not really enough to throw the switch, is there any way to decreas the spring thension on it?
