seachest
Thread starter- Joined
- Aug 20, 2011
- 43
My 1987 1.8 L 140HP Sea Drive is causing me some headaches - I am getting quite a bit of water into the pan which vaporizes and chokes the motor out - I found my original post and your gracious replies re OMC Sea Drive Water Flow from Sept 3 - 6 2010. This boat is stern heavy and rides low in the water - I suspect that the water is getting in around some plugs and possibly around the overboard discharge - My Q is can I caulk (3M 5200) all of the plugs in the pan without any adverse effects (eg water retention) - I also want to replace the seal around the cowling & pan - I brought the seal and can't find it so I figure duct tape may help test temporarily. Are there any othe places I should be looking? I checked the siphon hose which lies in the pan and it is working perfectly.
Thanks in advance for your expert advice / recommendations
