- Joined
- Jul 23, 2011
- 53,297
Looking good
I gave it an honest look last night and I just don't think I'll be ready by 12/1. I'm going to try to splash 12/5 if the weather behaves and I can get the last few things done needed before putting it in the water for the first time. There will still be work to do after splashing before it's "done"....but is it ever really "done"?Hey @todhunter , if you splash in the next week, we can nominate you for the SOTY
![20211117_072520[1].png 20211117_072520[1].png](https://forums.iboats.com/data/attachments/352/352805-19d56196bb827575d50af47ffa57f8c8.jpg)
Did you etch it?Well, it was either bad prep or bad paint because it was still wet in spots after 10 hours. I'm going to blame the paint. So I stripped the paint off. Now I'm curious how it will look with a raw aluminum frame on the boat, so I'm going to strip all the frames and set it on there to see. I don't think I'm going to like it, but who knows?
Nope, but I didn't take it down to bare metal originally either...just scuffed up the paint that was already there, so I don't think lack of etch would cause the paint to not cure...maybe not adhere, but it should have still cured.Did you etch it?
Thanks for sharing. I honestly think I'm going to paint it still, but we'll see once I get the other frames stripped!Mine has bare aluminum. Doesn't cause me any problems, and no concerns about scratching it. I get glare off the dash, though. Bare aluminum can help define the windshield an make it part of the overall shape of the boat.
However, black frames tend to disappear when you look out through them. There is a black joiner strip on each side of mine where the curved corner meets the front flat. You can see it in my sig pic, but you really have to look.
Stare at the example I posted here and you can see what might impede the view of the water ahead. Anything above the trees doesn't matter.
I realize you don't have a walk-thru windshield, so ignore that part. Just trying to give you a visual to help you decide.
Are you talking about using an etch primer, or something like Alumiprep 33 (or both) prior to paint?Prob the 2 dif paints had an argument. Take to bare and etch is all.
Being NOT the paint guy but around awhile, Scott summed it up very well. I wouldn't have had the exact info whereas I have not done that process yet but intend to.mine were originally anodized aluminum. all I did was scuff, chemical etch, etching primer, epoxy primer, and then snow-white top coat.
