1987 Renken 1750 LTD Mercruiser
RenkenII
Need some help.
Just purchsed this boat and it has been out of the water for a number of years. First - how do I identify the engine - all the stickers and such are no longer visable. Second - it has no spark - gets fuel - obviously wont run. Third - no altenator? How does this work? Being new to a boat, any information would be greatly appreciated.
nola mike
Re: 1987 Renken 1750 LTD Mercruiser
count spark plugs. take pictures and post (outdrive as well). if it's a 4 cylinder with no alternator, it's a closed cooling 470 engine (welcome to the club).
EDIT: Meant to include this link as well for troubleshooting your ignition:
http://forums.iboats.com/showthread.php?t=335407
Don S
First, you need to tell us what size engine, 4, 6 or 8 cyl engine. A few pictures of the engine and drive couldn't hurt.
Fishermark
And if you are a member of that club, be sure to have some thick skin. Not a lot of lovers of the 470 here. ;)
RenkenII
Thanks for the help so far. I'll get some pics up soon, but for now, here is what I do know:
Four Cylinder
Closed Cooling - (has the coolant tank on the opposite side as the distributor)
No Altenator
Alpha 1 Outdrive (which the Power Trim is stuck with the outdrive high - getting oil as I think its just low - pump does run)
Four Cylinder
No Altenator
Ayuh,... Lucky you,... It's a 470...
