1987 Sea Nymph SS175 Fish & Ski Rebuild - Tons of pics! *Paint COMPLETE*
lmuss53
Re: 1985 Sea Nymph 175 Fish & Ski Rebuild - Tons of pics!
Looks good carpedium, what bedliner did you use?
What are the issues with your motor, maybe we can help you some here or you could start a new thread in the Johnny/Rude section. I have had 3 of these OMC triples and know my way around them pretty well.
carpedium
Thanks Larry. I hope your vacation was enjoyable!
I used Liner X-treme (http://sprayonbedliners.info/home.html) Its really tough stuff. I sprayed some on some of the extra wood and aluminum I had laying around and, and am going to go at it with a hammer after the full-cure period of 5 days passes. It was dry within 16 hours (enough to walk on).
Applying it with the texture spray gun I used takes some getting used to. I still have to spray the motor well, but first I need to caulk the seams and get it cleaned up.
ugh the motor problems are the last big hurtle to getting her back to useable. I just posted a motor thread:
http://forums.iboats.com/showthread.php?t=545676
Teamster
wd40 also works well for adhesive remover,....
carpedium
Thanks for the tip
carpedium
Last night I was able to get half of the hull prepped, with 3 coats of primer (4 if you count the ZC on bare AL spots) I sanded really well between each coat.
The main prep was the most difficult - The goofoff worked alright, the WD-40 didn't seem to work well with this type of adhesive. I ended up just wiping down with a lot of acetone and that did the trick. After that, I brass brushed and of the chipping or irregular spots (not many) and gave the whole thing a good scuff with 150, then 220, then 500 grit. In between primer coats I sanded with the "between coats" pad pictured above - I love that thing. My can of ZC is kind of spitting and sputtering now at the tip, so there was some nubs to sand down.
In between coats I also got the old livewell drain plugged up. I ended up going with 1/8" aluminum plate and epoxy to seal it. I took a 3.5" by 7" piece of aluminum, bent it so that it was at an angle, then drilled it out using 3/4" centers on the rivets all around the plate. I drilled 3/16 holes first, and riveted the plate to the hull using two of those, one in each corner. After that I drilled the rest of the holes through the hull and plate using a 1/4" bit - so everything is perfectly aligned. All that was left to do was drill out the 3/16 holes, and everything was golden. After everything was sanded, cleaned, and acetoned I slathered epoxy on the plate and stuck it on with the rest of my 1/4" closed end rivets. Popped it on and it is not going anywhere. Based on the manufacturers data on the rivets, the strength of the patch exceeds the shear strength of the aluminum. I made the patch twice as long so that I could bend the bottom half up to work as a transducer mount. This way I wont have to put more holes in the transom when I mount the transducer. Last night I also plugged all of the old holes with rivets and epoxy. I also drilled two core samples in the transom to be sure I was not wasting my time here. The shavings were light in color with a red hue. The wood around the motor mount holes also looks good. I will get some pictures of that to post soon.
I got up early this morning to finish prepping the Transom, sanded, acetoned, and put the first coat of primer on (ZC). Tonight I plan to get the other half of the hull prepped and to the same point as the first half. Then tomorrow I can clean out the shed, experiment with the color, and start spraying my main coats.
Pics of the progress:
carpedium
I also need to get the boat a few inches back on the trailer. Anyone have any tips as to how to accomplish this? Hook trailer to truck, pull on transom eye's with 4 wheeler?
carpedium
Also made a video of putting the pop rivets in with a pneumatic rivet gun:
jasoutside
Um, can somebody please explain to me why I have been using that stupid hand riveter all this time?:facepalm:
OK, air riveter next on the tools I need to get list:D
Teamster
Same thought I had Jas,..............
carpedium
I got the power TnT parts in the mail from Canada today... Only to find that the kit contained this:
Instead of this:
I called the place I bought the kit from (Hastings Marine) and they are working on seing if they have another one that they can ship out. I hope they do!
I also got the rest of the transom prepped and primed on my lunch break, and was able to move the boat back on the trailer using brute strength.
Woodonglass
Honorary Supreme Mariner
Yeah, I've heard that "Brute" guy is pretty Strong! As I get older though, he seems to be getting a bit weaker. Haven't figured that out yet. :confused:
fat fanny
Don't worry Wood knowledge is power!!!!!!!
jigngrub
Price a pneumatic rivet tool and you'll see why you're using a manual one.
jasoutside
carpedium
Yes, highly recommended!
carpedium
Hell yes. Thanks for your help Wood!
carpedium
Last night I got the other side de-scuzzed, sanded, acetoned, sanded, and primed (2 coats).
This morning I got the whole boat sanded again, tacked, then primed for the final coat.
ehh, it looks the same as the last pic, but I uploaded it so its gonna get posted!
carpedium
My plan:
This oil-based Primer should be dry in 6 hours, so by 5:00 this afternoon it should be very ready to sand and prep for the first round of final coat. After its prepped, I'll mix up some of the paint, about a half quart... spray the transom... and see if my black/aluminum mix will have any issues. If no issues I'll continue spraying the whole thing. Tomorrow morning sand & prep - coat 2. Tomorrow eve sand & prep - coat 3. If I have enough leftover for a coat 4 i'll do it but I think 3 coats with the hardener should suffice - especially with 3+ coats of primer on the thing.
Any thoughts/critiques/suggestions?
Woodonglass
I'm anxious to see how the Aluminum paint mix turns out. Skeptical, but hopeful. 3 Coats should be plenty.
