- Joined
- Oct 25, 2011
- 25,312
Re: 1987 Sea Ray Seville "Re-Re-Restoration"
You can use a plastic putty scraper to pull gelcoat across small pin holes to fill them, rather then letting the gel 'dry' and using a filler.
Most use a 2.0 tip for gelcoat work, this might help get the gel thru the gun.
Does the Duratec eliminate the need for air inhibition for the gel to cure? I'm familiar w/ it, but not well enough to know.
Unless you use wax, PVA or otherwise cover the gelcoat, it may not cure, and may not be dry tomorrow.
