Woodonglass
- Joined
- Dec 29, 2009
- 25,933
Re: 1987 Sea Sprite 225 SSB transom re build.
Uhmmmm...
Uhmmmm...
37 cubic feet at 60 pounds per cubic foot is over 2200 pounds of flotation.
is that enough or not enough?
Based on the weight of your boat, motor and gear.
some components add bouyancy gas is only 6 pounds per gallon wood floats seat foam floats Etc
Jbcurt00 Im just looking at replacing what was removed from the boat!
I see Urethane Foam , Expanding Marine Polyurethane Foam has an 80lb kit that does 40 Cubic ft for $264.00 + shipping is that correct?
If you can add a little more, it won't hurt...
This is correct, assuming you get full expansion, which depends a lot on the temps you have when pouring it...
This amount, if you used all of it would give you approximately 2400 lbs worth of floatation...
Like jbcurt00 mentioned, some things in the boat are naturally buoyant, but having more of a safety margin is always a good thing...IMHO![]()
So increase the weight of the foam or find more places to put it?
is that enough or not enough? Based on the weight of your boat, motor and gear.
I only used 75lb foam as an example, because whatever foam they did use, isn't what's available to us as DIYers. I have NO info on what type of foam SeaSprite may or may not have used. But if you're using 60lb foam, in the exact same areas that were foamed before, it would appear that the manufacturer HAD to use a different buoyancy foam. Or the USCG would have barred their sale in the US.
Monohull inboard, inboard/outboard boats and airboats less than 20 feet in length must comply with a flotation system called Basic Flotation
Monohull boats under 20 feet in length and rated for more than two horsepower must comply with the more sophisticated flotation system called Level Flotation.
Manually propelled boats and boats rated for outboard engines of 2 HP or less must comply with the Modified Level Flotation requirements.
The foam might have been a structural component as well.
I only say this because according to the USCG regs., only boats Under 20 feet are subject to the floatation foam requirement...
This is an excerpt of page where this info is located...
Here is a link to the actual page...Flotation - ApplicabilityHTML:Monohull inboard, inboard/outboard boats and airboats less than 20 feet in length must comply with a flotation system called Basic Flotation Monohull boats under 20 feet in length and rated for more than two horsepower must comply with the more sophisticated flotation system called Level Flotation. Manually propelled boats and boats rated for outboard engines of 2 HP or less must comply with the Modified Level Flotation requirements.
Figuring out the actual flotation requirements for a given boat requires calculations based on Coast Guard formulas and are actually only required to be followed by manufacturers, not backyard boat builders.
All that being said, I personally would rather go to the trouble and expense of adding this "Insurance policy" to my boat in the unlikely event that I should ever need it...
Here is a link to figuring Basic Floatation...
Flotation - Basic Flotation
Here is one link to the formula for figuring Level floatation...
Flotation - Level Flotation
Here is a link to figuring the Modified Level Floatation...
Flotation - Modified Level Flotation
And here is the table of contents pertaining just to floatation and all its formulas, requirements and uses...
Flotation - Table of Contents
It is long and drawn out and somewhat complicated, but if you want to learn all about it, this is the place to start...
Have fun!![]()
