ok! here goes, started the other day tearing out all the rear interior of the boat so I could get right down to the bottom of the keel inside the bilge and down around the transom/gimble plate to inspect the transom. Just what we had expected, using the tap/rap test I determined my transom is very soft from the bottom up about 8"-10" and about 12" each side of the center/keel/drain hole. The 2 stringers that run along side the motor mounts are also soft from the transom forward about a 1'. So Ive decided to pull the engine and cut the floor back from the back of the fuel tank to the transom and see what I might find. I'm sending pics so you have a good visual of where Im at and what Im seeing. Comments appreciated!
