At least your stringers are wide enough to do that. This silly boat I am slowly becoming in debt for has stringers 3/4". I'm still trying to figure out how I can get 15 ft of stringer when its so thin! I'm seriously considering going back with 1-1/2" just to make life easier laminating together a splice joint.
Ayeee, the discussion I had on here with a few guys between plywood or dimensional lumber.
I decided to do dimensional since that's what I took out of the boat, and it ended up being a hair easier to glass around. A lot of other boats couldn't have that as an option because of the required height of the stringers. Those with the deep hull are better for cutting waves, but require much taller stringers. My boat is supposed to ride on top of the water, so 2x6 lumber was perfect for me.
I watched project glasstron on youtube by JMink. he did a glastron that may be similar to yours, he also used dimensional lumber for his stringers, although people on here swear by layering up plywood due to the multidimensional strength being the same.
Heres a link to his playlist. Its a good series.
https://www.youtube.com/playlist?lis...3CiTJs4-21ol2d
Also if you are doing ply, I would recommend feathering them together, do 2 layers next to eachother rather than just 1. Or heck, do 3, then you could have a better tongue and groove joint between the 8' sections.
