Hey Tim (and anyone else who is still listening)!
Sorry for the delay, unfortunately I've been having car issues and trying to chase down electrical bugs that the dealer and shops cant find. Super frustrating. Although thats what I get for having a 13 y/o jeep with 165k on her. Not the most, miles, but getting up there.
Also been snow skiing most weekends, you caught me, we've got about 18 days on the mountain so far... We did a trip to Steamboat, CO and then also to Big Sky, MT. Both were fantastic and love knocking some destinations off our list. Back country this year started rocky and has had very high avalanche danger for most of the year, so less on skins this year than last.
Regarding the boat, because
thats what this forum is for... IVE BEEN A LAZY BUTT. and its been cold, and I've been working on that damn camper trailer more than I expected since some of the wiring was messed up and I had to tear out some of the walls I put up. But all those "and"s sound a bit like excuses.
Apologies to all, and thank you for those who are still following along. I refuse to let this project die, and am going to give it a good push to get it in the water by this summer.
I had presidents day off yesterday and rather than going up into the mountains to play in the 18" of fresh powder (which my friends sent me many a pic/vid of) I got some work done on the boat, cleaned the garage, and re-setup my bench. Here is the list of things that Ive gotten done since my last post (apologies for the lack of pics):
- Got the seat base mounts attached to the bases and set in place. Just an extension of the pics a few posts ago. But final stages before screwing them down.
- installed new electrical relay.
- when I was originally working on the engine, I wasnt getting power to my plugs, hoping that this relay was the issue, still debug left to do on the engine.
- installed new resistor on motor
- again, easy electrical component to replace and try to troubleshoot electrical
- probably not root cause but the old one was very fragile and corroded
- mounted steering cable and adapter
- mounted throttle cables to throttle body
- installed throttle body
- installed rear cleats
- These are the same ones that Tim suggested and they look great!
- these were more of a hassle than I expected. But hoping they will aid in "bumping" the rope over the rear seats.
- May have to install something else like suggested by others.
- Drilled out tower mount holes
- Cleaned and greased tower mounts
- when I took these off, most were seized. So I removed corrosion and added grease to the contact points in order to allow for actual functionality.
- installed tower mounts
The "recently completed" list looks longer than it really is, but its mostly small stuff, here is the real list of TO-DO:
- plug and glass foam holes
- where I drilled through the floor to pour foam below the deck
- Paint floor and hull walls
- went with an epoxy paint as recommended on this forum
- Rub Rail install
- I cleaned up the rub rail and need to buy a new insert for it.
- mount seats to floor
- although I wanted to glass the bases down, I am realizing that the temp is not conducive to glassing in the winter.
- not super happy about just using brackets, but if it bothers me enough, its something that I can realistically redo later.. although it would certainly be a pain.
- I may mount the passenger seat via glass, because this would be a permanent feature.
- Welsh Plugs
- looking at the engine this weekend I realized that after bashing my hand putting in the port side, I didnt finish putting back on the starboard side.. so that was dumb. Now going to be a royal pain to get to since the engine is back on its mounts.
- Anyone have a good technique for doing this in the boat?
- Engine Debug
- As mentioned earlier, the engine was turning over but didn't have any spark at the plugs. Trying to determine issue, quite a bit was done to this engine, but not sure if it was running before.... More on this when I get to it.
- install engine hood
- need to do engine debug and welsh plugs before this to have maximum access to the engine components.
- install foam flooring
- we purchased rolls of foam flooring which will need to be cut and fitted.
- New glass for windshield
- one of the windshield panes was broken
- install windshield
- dash wiring
- I had to cut a lot of the wiring when I removed the cap of the boat, hopefully my labeling was good enough to put it back together.
- Side upholstery
- upholstery for the sides of the boats were 100% rotten, looking at the admiral to retrofit some new ones.
- Speaker install
- I repainted the existing speakers but need to run new wire and install. (hopefully they work)
- will test the sound system before install of everything.
- need to determine if either of the 2 receivers in the boat work at all.
- Wood accent trim
- trim pieces have been sanded and stained, just need to be reinstalled
- Decals
- looking at getting some new decals for the boat, need to just pull the trigger on some
- some buffing still needs to take place prior to these going on.
Big plans for this boat, and super frustrated at how many/long my delays have been with no progress. BUT not giving up yet. Thanks for all of your support and I hope to be more active in the coming future!
