1987 super six 150 hard to start and wont idle
ggrounds
i am having problems starting this motor an dwhen it does start it wont idle but will run at higher rpms. also when slowing down off plane it dies almost like it floods itself out if any suggestions they would be appreciated.
alphamax
Re: 1987 super six 150 hard to start and wont idle
I have had a similar problem with 100 hp ,carburettors have been cleaned in particular of low rpms fuel jets.
deejaycee_2000
you need to give those carbs a real good clean .......
JUSTINTIME
rebuild just do not clean them
deejaycee_2000
isn't that the same thing ..... rebuild .... clean .....
JUSTINTIME
i consider cleaning just spraying it down and putting back together
rebuild is using all new parts and going through each circuit in the carb
