1987 Tilt/Trim woes Please Help
ssuajk
I had the usual tilt/trim leakdon on my 87 Froce 125hp, then I followed Clantons method and tackled the valve body. ( I got the valve body w/ snap rings on the pilot valve) anyways the job went well and Clanton is my hero. It ran fine for 2 weeks then yesterday I was tilting up and I saw a fluid slick in the water.The fuid was red and to make a long story short the pilot valve you can't see(towards stern) popped out and I lost the pilot valve and snap ring. Does anyone know or have a pilot valve and snap ring they would sell me? please help me
The Marine Doctor
Re: 1987 Tilt/Trim woes Please Help
Was there any damage to where the snap ring goes?<br /><br />If so this will be a reoccuring problem.<br /><br />Send me an email...I might be ablt to source some used parts for you.<br /><br />marinedoctor@shaw.ca<br /><br />TMD
ssuajk
First let me say Thank you for replying, I appreciate your quick response.<br />There was no damage, I think I simply had a worn snap ring, but i will carefully chase the snap ring groove with a scribe type tool just to be sure. I would appreciate any help you can get me in finding a pilot valve and snap ring, the shuttle valve is still in there, thank goodness.
clanton
I close my eyes every time I put pressure on the pump with snap rings. You are on the right track, clean groove, new snap ring. I dont have any valves. I will check a shop later this week, he may have something.
ssuajk
Thanks alot Clanton,<br />I do hope their are others in this network of fine peeps who can help me get some spare parts.<br />I would love to use my Tilt/Trim system again.
gotsaved
dear ssuajk. when i first got my boat the tilt and trim didn't work. it had the same pump you have. the same thing was wrong with it and i bought the other kind used. i think i still have the old one and it has the piston and snap ring in it on the opposite side or the outward side.if they are the same i can help you out. you can e-mail me at rdante@gcnetmail.net or call me at 304-788-0597 after 6pm eastern time.my name is randy. catch you latter.
ssuajk
Wow, You guys are the greatest and yes the parts are identical, Thanks once again Randy BTW you got mail.
ssuajk
Yee-Haw<br />Randy is the Mannn....Thanx Gotsaved<br />I will promise to help others just as you have helped me ..... The part you sent me will work and yours is on the way... :)
