1987 Yamaha ProV150hp
Leonard Ray
I have a 87 ProV 150 that I have been working on. It starts great runs good gets up on the water good for about 100 yards at 5500 rpms and then starts going and down in rpms and then will not turn over 4200 rpms. I have clean and rebuilt and the carbs ,new fuel pumps and fuel lines. You can let it set for a day and it does the same thing.Any ideas what I need to check?
Thanks
99yam40
monitor the fuel pressure and vacuum while problem shows up
You can also use a clear tube to look for air being sucked into the system
Look in the frequently asked question section of the forum for a write up on testing fuel system
Also check fuel pump to make sure it is not leaking and dumping fuel into crank case
Leonard Ray
When I pump the ball up i see no leaks but one min. latter there is no fuel in it. All the fuel has runs back down to the tank.
Leonard Ray
I replaced all the fuel lines and put new clamps a all connections. It helped some but still will not turn over 5000 rpms. Where would it be losing vac. at?
Leonard Ray
Not sure how to. I have tested it spraying starting fluid around carbs . But only does it under a load.
99yam40
did you look like I said in the frequently asked question section for fuel system testing?
Leonard Ray
Can any one tell me what the float height and float drop is on this engine? And what do the idle mixture screws set on?
Thanks
