I recently tried to set the timing on this motor. I found that I had to advance the timing screw as far as it would go to get it "near" the target setting of I believe 16 degrees at WOT. I cannot get the timing mark to go any closer than 14 degrees. Also, my tach is now giving me readings all over the board. I think there is something under the flywheel that needs to be replaced. I am not sure what. Is it a stator? Where do I get the socket at to get the nut off the flywheel? All my sockets are too bulky. Will changing the stator fix my tach problems and timing problems? Please help!!
