evinrudexp
- Joined
- Apr 13, 2006
- 34
Hey Guys!
I have an issue with my 1988 Evinrude XP VRO that I was hoping maybe some of you here can help me on. Basically (or not so basic!), the motor runs nice in neutral and at idle when in gear. BUT as soon as I get on the throttle in gear the motor wants to stall and will die if I dont pull back on the throttle. In neutral is revs up fine, but in gear it wants to stall out. THEN, occasionally it will start to stall but then take off all of the sudden and run great at WOT before it will again loose power and want to stall.
I have replaced the plugs but no change.
I tried to pump the primer bulb but no difference.
Im not sure if its a fuel problem such as my gas tank, lines, fuel pump, or carbs). Or, if its electrical such as power packs, coils, etc?
Any ideas???
Thanks in advance
Any ideas???
Thanks in advance
