dkonrai
Thread starter- Joined
- May 9, 2009
- 719
newly aquired motor, had a problem that it wont shut off. have not replaced the pp yet.
question, motor runs then eventually will die like its out of fuel after about a five minutes or so. the ball gets soft, and i can barely see any fuel in the clear filter at idle. the motor then just quits like its out of gas. pump the ball and it fires.
it doesnt want to slow idle.
fuel pump?
i tried the ball with out connecting the motor and the ball gets hard, so the tank and primer should be ok?
motor seems like its low hours. the transom clamps have no chips in the paint and the motor was stored in a garage.
compression is 130 psi in both cylinders
fuel pump filter is clean
carb was pulled, and i just used some carb cleaner and a compressor to blow out the carb ( so should i give the carb a bath? )
new plugs
have spark, but it doesnt shut off
owner ran the gas dry everytime he used it.
why did the engineers make it so hard to pull the carb??
thanks
dino
fuel pump?
new plugs
thanks
dino
