88 Capri (2022 SOTY)
Thread starter- Joined
- Aug 25, 2019
- 864
Hi all,
I'm looking for some advice and or direction.
I've had a common problem since I first got my engine running.
The engine starts great and throttles up great but idling has been nothing but frustration!
When trying to get it to idle near the required rpm it won't go lower that 900 maybe slightly less but I can tell it's running a bit to rich, stuttering and a slight miss. I've had this happen with the carburetor that I purchased (snoockered) and the original one I rebuilt.
I had an 1980 Pontiac Sunbird years ago that idle very rough but don't remember the other symptoms, other than idling it accelerated perfectly.
I know the counterweights were worn on that engine which the dealer said was the issue so could that be my issue here? I also read that a bad coil could potentially cause this issue but I installed a new internally resistive coil with the power wire running to the key switch (resistor wire was missing).
The points, plugs,wires,cap,rotor have been replaced since I acquired the boat.
I appreciate any feedback someone might have.
