Re: 1988 35HP Merc transom clamps
Joe;
Not sure about aftermarket parts. You can sure see from the pictures why the clamps failed. When you remove those bolts, you will probably find a square portion underneath the head. These look a lot like carriage bolts which shouldn't be used there.
If they were my clamps, I would see if a good welder could tack them back together and then I would use a solid bar with holes drilled to match the width of the clamp hole centrelines and install that over the clamps with the new bolts going through the bar, the clamps and the transom.
You might have to use a crossbar, thick enough to enable slots to be cut to match the portion of the clamp above the bolt holes where the clamp protrudes out rearwards.
Thoughts from others??
Gerry
Does this make any sense
