1988 364v Comanche bass ranger
holstein9193
I recently acquired a bass ranger. I have been trying to restore it. However the fuse box has me a bit perplexed. How does the fuse box get power to run the fuses? There is no negative or positive lead wires on this thing. If someone could please advise I would greatly appreciate it. I have attached pictures of the box.
The large red wire is your feed. There are buss bars.
Ground wires go to a ground buss
The fuse block is only the B+ supply to your circuits. There is a buss strip in the fuse block in your pictures
holstein9193
Ok? Call ignorant for a brief moment ( I appreciate you responding), but are you calling the six screws around the fuse the bus? I thought those were just there to keep the fuses aligned.
No, the stamped metal teminal strip
The 6 screws are holding the 3 mini fuse holders in a piece of plastic
