Joshpike15
Thread starter- Joined
- Jun 30, 2021
- 4
Hello to all, new here so be gentle haha. Just bought a 1988 Rinker 186 captiva. Picked it up with trailer for $2500 and it is, well what I thought to be, in decent shape. Motor starts right up every time. It had an overheating issue I found and resolved by changing the melted impeller and that fixed that issue. I changed water pump, plugs, wires, distro, points, belts, thermo just to freshen it up. Got it out on the water and did a test run. Did decent for the most part for well over an hour, stuttered at top end and felt a little sluggish. Was on the way back in and it did not want to run good at all. Worst it ever has, to my knowledge. Would not go over 2500 rmp and at 2500 it was struggling to hold on. Just did a compression check, should have done that before testing..lesson leaned, found 2,4,5,6 to have 145-150 psi...1 and 3 have 0...pulled the valve cover and hand spun motor over and all spring and rods move in sync like they should. At a little bit of a loss on this one. Oil looks great, no water there. I assume all I can do at this point is fully remove the manifold and take the head off to check conditions? Any advice is more than appreciated.
