1988 4 hp Johnson Sailmaster adding tell tale water drip
j_k_bisson
Has anyone ever added a tell tale water line to a 1988-1991 4 hp Sailmaster outboard. Model number J4RLCCS. I was thinking of drilling the Exhaust Cover plate where the water line passes by it at the top. I was going to use a 10-32 UNF x 5/32 Barb 90 degree fitting. This would only require a #21 (0.1590") tap drill hole. I was also going to route the water to a 6 hp thru bottom cowl fitting (0336597).
My questions are these;
Anyone ever done this?
Where did they put the hole for the fitting?
For my proposal, does anyone have picture of the block with the exhaust cover off?
What size of hose is OMC 0328388?
What is the size of hose that fits bottom cowl fitting 0336597?
Any and all help would be great! I will be documenting this project as I go. Right now I am collecting parts...
