FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
I have the carb's down for cleaning and see that the main pick up tubes, 4 holes on opposite sides, have split along the line of the holes on both carb's. Does this present a problem.
Thanks Guys. I will try soldering after a good clean and pulling the halves together. I have rebuilt countless johnyrude carbs but I have never seen this problem. Learn something new every day.
I have successfully soldered the tubes but I am puzzled as to how this splitting has come about. I note that the color of the carb bodies is different to the bowls. Could this indicate that the bowls are not the originals. If the small pick up tube makes contact with the bottom of the bore this could cause the tube to flex and possibly cause the large tube to split. I note that without the bowl gasket the small tube does contact the bottom of the bore.
Any thoughts on this before I try reassembling.
Couldn't wait for a reply so the carbs are reassembled, very carefully, with new kits and the motor runs very well. Lake test to follow.
I would still like to know how the tubes came to be split.
