1988 40hp johnson bearing carrier removal
sambrigman
I have a problem in my lower unit, can anyone tell me if the bearing housing screws out or pulls out? Thanks
sambrigman
could you tell me where i can find the carrier puller?
F_R
Honorary Supreme Mariner
Harmonic balancer puller from the auto parts store. Some stores have them to rent/loan. You will have to find some suitable bolts to use with it.
Are there threaded holes on the 40 model bearing carrier ?
danintruder
on my 1999 jonhson i used the locking tabs holes ,very easy to pull out in my case with threaded rods.
sambrigman
there are no holes, thred or anything to pull my carrier
Slide hammer.----Piece of threaded rod with a hook bent on the end might work.
F_R
No Title
A few methods have been used through the years. Unfortunately, I don't know which is applicable to your motor. A J-rod with a slide hammer as racerone just mentioned is one method. A couple more are shown in these pictures
