I have a 1988 50HP Force. It has sat for fifteen years and only has 15 mins on the motor. I have added about six hours to it. However, on the last run the engine lost power (Like it was running out of gas) and started smoking. I immediately shut it down and got towed to the boat ramp. I checked the compression on the cylinders (2 cylinder) and found the top cyclinder had no compression and the lower cylinder had about 25lbs of compression. After reading for several hours on this web site (which I think is just excellent) I concluded that maybe the head gasket went bad. However, I would like to confirm this. Can anyone out there give me suggesitons on how to confirm the bad head gasket? Also, it appears as though I am not getting any spark at the plugs. I also would like a recommendation on a good, reasonably priced, repair manual. Note: The motor is on a 14.8ft, v-haul bayliner. Top speed with only myself in the boat was just 21.5mph.<br /><br />Thanks,<br /><br />Trex3648
