relics hunter
Thread starter- Joined
- Jun 11, 2010
- 118
I had done a simple clean of the carb last year when I got the motor and it ran well (weekly trips to the shore) until recently when it was lacking power a bit. Also in the last month I have replaced the fuel pump one weekend( had to use the bulb as a pump to get home one day) and the fuel bulb (cracked)the next weekend. Lat weekend when it wouldn't get up on full throttle and bogged more going in I ordered a kit for a proper rebuild. Well now nothings going right. I can not get it to stop leaking out of the air hole on the top side. I looked over all the posts about the subject and everyone says float adjustment or needle sticking. I of course need some special gauge 324891 that I don't have and most references say to adjust the float level or a hair higher. The old one was not close to level and it ran just fine until recently, so I am real confused. I set the new float to recommended almost level and 1-1 3/8" fall on the other measurement and it just leaks gas out the hole after a few pumps of the fuel bulb. I have tried the old float, I have tried different slight changes, and nothing helps. I am at a loss and wonder if the nozzle well might be involved in the problem. Maybe it's not sealing, it seams to be a wobbly piece that hopefully sets right during assm. Help
