1988 6hp SailMaster primer system/nipple?
fishkisser99
J6SLCCS, serial # B7629852
When I pull the primer knob, fuel sprays out of the end of the hose fitted to a brass nipple on the intake manifold instead of into the nipple/manifold. Is that a brass check valve, or should it be unobstructed? Prodded gently with a piece of wire and seems blocked...
Cannot seem to locate that part on any of the online diagrams--suggestions?
tks--
--mja
tashasdaddy
Re: 1988 6hp SailMaster primer system/nipple?
it should flow freely. i believe it is pressed in. had the same problem. finally got a small wire thru it.
