1988 85 hp Force prop help
FORCE10
Hi all,
I need to know what hp and yrs of Force and Chrysler
will fit my motor
any help will be appreciated
Force10
usskydvr
Re: 1988 85 hp Force prop help
Take a look at the attached
FORCE10
thanks usskydvr!
that told me just what i needed to know
1977-89 force/chrysler prop will fit my motor if i looked at it right
i have a 17p,decent hole shot but i want a little more (of course) i'm think a 15p would accomplish this,any thoughts?not sure what my rpm's would be if the blade tip wasn't broken an inch back on one blade (5k?)
going to a 15 should put rpm's quite a bit higher right?
thanks,Force10
usskydvr
Going from a 17 to a 15 in the exact same make/model prop will give 300-400 more RPM.
FORCE10
Once again,thanks usskydvr
don't know what to make of the numbers until each prop is actually run on the water.guess thats true for everyone tho' huh?
Just like to be as close as possible to start with.
Force10
