Hi folks,
I searched old posts and found similar but different problems. Im looking for orderly steps to take to diagnose problem.
I have 1988 90 HP Johnson that runs (has) run great. It is on a 16 ft center console flats. Does 32 at top speed according to GPS (no tach). I keep the boat in salt water. Always flush with saltaway and remove periodically for hull care, etc. (Bottom has anti fouling paint and is currently clean)
I was running WOT after a day of fishing. Ran great as usual. All of a sudden, it dropped about 20% or so RPM. It was sudden and smooth, in fact I looked to see if my dog had knocked the throttle control back. It had not moved. It ran very smooth, no sputtering, no odd sound, just lower RPM and slower speed. I backed it down some, then put it back up, still maxed at the lower speed.
I came to no wake zone, throttled to idle, and it ran slow fine. Smooth, no roughness, nothing. I went just above idle for 8 or so minutes and opened to WOT when passed the bridge. Accelerated smooth, no sputtering, took a little longer to plane, but ran at same lower speed. It was almost like I advanced the control lever 1 inch short of full, but it was definately all the way forward, Ran like that rest of way home,
So, What things should I suspect and what order should I diagnose? I have a manual and am pretty handy,
Thanks in advance for your thoughts!!
