1988 90hp Johnson By pass cyl covers
montauk1
I have 4 by pass cover cylnders, two have small fuel line connectors and two dont, can any one please tell me the proper cyl each one goes to.
Dhadley
Re: 1988 90hp Johnson By pass cyl covers
On the covers with 2 nipples one nipple was for the primer and one was for the recirc system. If you have the primer lines going in the top of the carb then you can cap off either nipple. If your recirc lines don't go to the by-pass covers then you can cap off both nipples. When we cap off both we just run a short hose from one nipple to the other on each cover.
montauk1
Ok Thanks, but the ones with nipples on them wich cyl do they go over, or on to.. 2 and 4 or 1 and 3 or 3 and 4 etc...
DargelJohn
I have a 1996 88SPL. Following pics show the bypass covers, nipples are circled in red. Both of them are part of the recirc system connected to the intake.
