1988 90hp Johnson QUITS RUNNING
montauk1
Hi
1988 Johnson 90hp (vro by passed).
Has a little problem starting at the ramp, once at idle runs great! Getting outside the Harbor I start to excelarate to faster RPM's runs good for about 3-5 minutes and then engine sounds like it is running out of gas and dies. Then it is really hard to get started. have to let it sit for some minutes. Keeps repeating symptoms. New Plugs, New fuel pump (do to bypass VRO) Rebult carbs. I did notice that the starboard plugs were some what dry and the port were very wet.
Can anybody help
Thanks
boobie
Re: 1988 90hp Johnson QUITS RUNNING
Have you checked your ignition yet to see if it will jump a 7/16 " open air gap?
montauk1
boobie, Hi,
How do you check you ignition to see if it will jump a 7/16 open air gap?
boobie
Go to any parts house and get an open air gap adjustable spark tester for around $10.00. Set it for 7/16 " and check your spark on each cyl. Should show a nice blue spark on each cyl.
emdsapmgr
Wet plugs can be an indication they are not firing. An inductive timing light is another common/good tool which will show the condition of spark on all 4 wires.
montauk1
Ok so all four jump a 7/16 gap, also did a compression test, 124 on all four. also took apart my carbs to check for any clogged orfices or jets, found a small piece of dirt or plastic in one,Could that couse the bog? Carbs were rebuilt a month ago no sticking floats or anything. What about water in the gas tank? Would that couse a bog and quit? or would that just make it sputter.
boobie
You may want borrow a 6 gal tank and hose and try it. This eliminates the boat fuel system.
montauk1
I found a good amount of water in the bowl of my carbs, also found good amont of water in my fuel tank, on top of finding one clogged injector (small piece of plastic) could this all cause engine to bog and die at higher RPM?
blimp
I think i had the same issue last week. My fuel/water separater was full of water and I was having the same symptoms. I have drained my tank, but i think there is still some water in there. I am going to pull the tank out and drain it completely while using smaller external tanks to run the engine.
waynehol
Yes, the small piece of plastic in the clogged injector was probably the high speed, thus the loss power and sounds like the water is the problem for starting
Just my .02
montauk1
Just drained out about 15 gallons of gas out of my tank, got to the last 3 or so gallons and trapped a whole cup or more of water in a glass jar. that has to be the problem with the WOT bog then die issue. T
boobie
"One clogged injector" ?????????????
