1988 alpha 1 outdrive pivot bolt removal tool
Lwarden
Was just wondering, Ive read a few threads about buying the mercruiser pivot bolt removal tool pn# 91-78310. Is there some that hold up better than others?? harder steel?
Bt Doctur
Re: 1988 alpha 1 outdrive pivot bolt removal tool
the tool itself is hardened
a 1/2 inch allen works in a pinch
last ditch effort is to weld the allen to the hinge bolt.
in all cases hi heat is required.
Lwarden
So I'll need hi heat no matter what? and we're talking the 2 pins behind the trimm senders correct?
Jimmy H.
Those are the ones. I rebuilt my entire Gimble assembly which had minimal corrosion and I still had to use a torch to heat things up a bit. I used the OEM tool to minimize risk of stripping anything and it worked great!
Good luck,
James
cr2k
Can also be had from NAPA PN 18-9861
Ayuh,.... Not so much High heat, but heat to soften the lock-tight it's set into...
I use a 1/2" allen key...
