tanderson2002us
Thread starter- Joined
- Jul 6, 2012
- 9
Serviced my Alpha One today to do the water pump. Everything looked great, replaced the impeller and gaskets after removing the lower unit. Pulled the upper unit to inspect the gimbal bearing and bellows and had a small amount (enough to cover the bottom of the bellows) of either gear oil or water mixed with gimbal bearing grease. When I drained the unit the oil looked fine.....no water what so ever. Perhaps I am leaking a small amount of gear oil in the bellows ? Or its water coming into the bellows mixed with grease? Again the gimbal bearing felt fine and smooth when rotated and the bellows and ujoints were in great order. Any advice appreciated....I do all the mechanical work on everything I own, this is my first Alpha One adventure.
Thanks!!
Thanks!!
