maxum247
- Joined
- Sep 18, 2007
- 1,363
Re: 1988 Bayliner Capri, Possible Restore
These are some pictures of my Maxum 20 footer which I beleive is made by Bayliner. I had that same seating setup. My boat has a wooden transom only in the center part of the stern, either side of the transom is 1/4" fiberglass only. I beleive the seat boxes serve a few purposes, one being to stiffin the transom to keep twisting and flexing of the transom from occuring while under power. One seat serves as a cooler and the other seat serves as a battery box. I removed my seats as they were rotten and discovered that the plywood in the transom was only in the middle section of the transom and there was no wood on either side, the boxes were glassed to the sides of the hull and transom with about a 1/4" thickness of fiberglass and was a lot of work to grind and chesiel out. The construction of the seats in my boat were built simple but are not the easiest to refiberglass back into place if going with the original layout. Keep in mind that my deck has been raised 4 inches so that I have more width across my deck area, so you can't see exactly what is involed in replacing the seat boxes.
I'm unclear wether you have this type of seats in your boat already or are thinking about building some like them, but if you already have them and there in good shape I'd leave them or try to repair otherwise.
If you decide not to put in this type of seating make certain to plywood the whole transom area with layers of plywood laminated together with epoxy glue and fiberglass the plywood in heavily to the sides of the hull and transom with heavy fiberglass cloth so that twist on the transom won't be a factor and the plywood will be protected from the weather and water and will be strong as possible.
max!
max!
