1988 bayliner speedometer
matt3100
i just bought a 1988 bayliner capri. The speedometer is not working. any ideas what i should check.
Re: 1988 bayliner speedometer
Ayuh,... Is there a Pitot Tube on the transom,..??
Hit It
Like Bond-o said, there should be a plastic tube running down the transom that hooks into a pitot, which is a plastic contraption hanging off the bottom of the transom. The speedometer operates on air pressure being forced through the tube to the back of the speedometer as water passes through a small hole in the pitot. It is common for the pitot to get broken off or plugged up. Let us know what you find.
jkust
Our older bowrider, also a BL, had this problem. A mouse actually got up into the gunnel and chewed the plastic tube in two.
RWilson2526
Don't waste your time trying to fix it. Get a GPS if you really need to know how fast you are goingl. Even when the pitot tube type are working they are not very accurate.
new2u_sd
Add me to the list. I have a 1997 Bayliner Capri 1704 with a Force 90 outboard.
There is no pitot tube that I can see. I traced the tube from the speedometer to the back and it seems to go into the motor. Is this right? Maybe I mis-traced. There are no holes or any indication that there ever was a anything attached to the back/bottom of the boat where something would have been attached.
Still, speedometer does not work and I don't know where togo from here.
Any ideas? thoughts?
