1988 DT30 Oil Pump
barroomhero
I have a 1988 DT30. The oil light would come on and the buzzer would sound. I switched to pre-mix and was wondering if there was a way to disconnect the oil injection... any ideas? Thanks
deejaycee_2000
Re: 1988 DT30 Oil Pump
to disconnect the oil injection, you need to take the oil pump off and just take out the little shaft that connects it, and put the oil pump back in it's place, you can also take out the oil tank and plug the pipe, but that is not necessary .....
