1988 evinrude 30 hp tiller convet to remote control??
lost_bone
Hello
I need help find right remote control from tiller on 1988 30 hp evinrude
but no eletric starter on 30 hp just pull and use remote control??
Haffiman
Re: 1988 evinrude 30 hp tiller convet to remote control??
You may use 'any' remote, but you will have to install the remote control conversion kit on the engine:
part no 0397488.
Go to shop.evinrude.com.
Parts
View parts catalog
Remote control adapter kits.
If using non-OMC/BRP remote and std C5 cables, you will even need cable adapters to fit the Evinrude.
lost_bone
part no 0397488.
Parts
View parts catalog
i did look but there no picture? i think i will need remote control with 2 level shift?
come with no eletric start...
lost_bone
does OMC parts #173286 remote control will fit 1988 evinrude 30 hp???
Haffiman
This was the link direction for the adapter kit needed, whatever remote you install.
As mentioned, you may use any remote as long as you get the correct cable adapters. The stroke neutral forward/reverse is standard.
