1988 evinrude 40 hp fuel pump conversion
TatorMan
I have a VRO equiped engine and am having issues with it, so would I'd like to replace the vro fuel pump with a non vro pump. Does anyone know what fuel pump or conversion kit to get?
Daviet
Re: 1988 evinrude 40 hp fuel pump conversion
Look on the port side of the block and see if you have #107, if so all you have to do is remove the plug and install a pulse type pump.
http://www.ishopmarine.com/ishop/js...nown&isFrPG=false&forItemCode=&pCode=C0211234
Here is the fuel pump for your engine, mount it and plumb in the fuel lines.
http://www.ishopmarine.com/ishop/js...nown&isFrPG=false&forItemCode=&pCode=C0211240
You will have to remove the VRO pump and all associated wiring and plumbing.
TatorMan
I don't see a #107 stamped anywhere!
TatorMan
Thank you for the help! Had to get someone with better eyes to find it on the diagram.
