shackle101
Thread starter- Joined
- Jan 11, 2012
- 140
Hi all I got this engine on a 22 ft deck boat and I noticed some issues when out on the water it seems to be sputtering at full throttle (ran fine a majority of the time till we got ready to leave) kinda like it's losing power. I notice the water pump isn't spraying very hard. Good amount of water is coming out but it's not spraying out like you normally see. So I did a compression test when I got it home and I got mostly 90-87 psi on all, but 1 which tested 70 or so. I let the engine warm up before doing that. I also tested again with a little mystery oil in the cylinder and still same results. So basically I have a worn cylinder or piston here? Do I need to just replace just that one? Also could it be just stuck I was hoping the mystery oil after sitting for awhile may clean it up. The engine has been sitting for about 2 years and it was supposedly rebuild 2-3 years ago.
Thanks for any assistance or suggestions you guys can provide.
