Mike in Tac
Thread starter- Joined
- Aug 26, 2010
- 50
I have a 1988 25 hp Evinrude outboard on a 14' Livingston - I got both off of craigslist. Today, I took it out on the salt water with my kids for the first time and had a blast. The motor worked great while we were out and about - after months of fiddling with it on my part, and then finally taking it to a mechanic to actually get it fixed in February.
On of the problems that I had previously was that after starting up the motor and letting it idle for a minute or two and warm up, I would gently lower the idle lever (so I could put the motor in gear), and the darn thing would stall on me EVERY TIME. It was ridiculous, and really frustating - because otherwise, everything seemed fine. I returned to the mechanic, and he tinkered with some screw near the top of the motor to set things right - and at no charge.
Like I said before, the motor worked great for me on the water today. However, when I brought the boat home and proceeded to flush the motor with fresh water, guess what happened? Everytime I tried to go from idle to in-gear the darn thing would stall. Not to mention, when the motor was idling, it seemed to be having a tough time - it would chug along and then every 10-20 seconds it would lose it's rythm and seem to "cough" - a couple of times this led to stalls when I still had the idle lever raised.
Does anyone have any advice? Is this an easy fix? The motor cost me $900 a year ago, and I've already dumped another $600 into it via a few trips to the mechanic and getting "new" (used) controls.
I'd like to avoid going back to the mechanic with my tail between my legs if I can avoid it.
Thanks a lot for looking,
MIT
MIT
